1 - 18 of 18 Posts
6.0 strokin
Can my 2003 f250 clear 35's with a leveling kit? What about stock suspension will it clear 35's without a leveling kit?
my uncle clears 315's with a leveling kit but they scrub the leaves when turned all the way. and from what ive read 315's are pretty much 35's. if im wrong someone please correct me.
Yes you can, I had 35x12.5 on 16x10 wheels, they would rub very little, the inerfinder needs to be pulled back, you can do that easy. I pulled it back and would only rub if turned just right and hit a bump. Off set will make it rub more.
6.0 strokin
Twan was it on stock suspension?
315.75r16 is a 34.6" tire they will fit If it rubs the fender liner at all ( I had a lift) just warm it with a heat gun wear welding gloves and push it in wherever you need to. This is what I did when I put 37x13.5" on but i have a 5.5" lift
No, I had a rancho leveling kit, 2-3" it was a 2004. On my 2006 they would fit for a town only with lift, put a 2" on it and they fit nice.
stock
mine still rubbs wit a 2.5 leveling kit on my 2003 35-12.5-20i will go to a 4" or a real leveling kit
On leaf spring they will rub, with coil springs they will not rub
6.0 strokin
Discussion Starter #9
So after seeing this I see I need a suspension lift, but do they rub bad with a leveling kit? I figure I'll save up and do a four inch lift eventually I just don't Wana get the tires and rub them to wear it starts wearing the tire. It's a big expenditure for me
What wheel are you going with size and back spacing?
On my 04 I pulled the inerfinder in alittle, around town and drit roads they never hit. If I was off road and turned just right they would hit. Mine never hit the springs. If you live near Colorado you can test fit my wheels to see what they will do.
on stock wheels, no problem. Any wider and you will have to trim the fender a little.
BRING DA AMBALAMPS
:whs: depends on the wheels. i have 35's but with 20x12's with 4.5bs so i had to trim the hell out of it...bumper and inner fender.
i got 35s on stock 2wd i just had to a little bit
Almost broke
My 35x13.5 M/T's on 20x9 (backspacing unknown) and 315s on stock wheels clear no problem except when I turn full tilt then they rub on the leaf springs. Nothing you cant live with.
I'm running a 2.5 leveling kit from rough country.
My 04 on a zone level kit, 35" 12.5 17s trail grapplers on 17x9 mb motoring wheels (discount tires brand) rubs very little, bearly kisses the spring clamp at full lock.
I have 35 1250 20 with stock and I had to trim inter fender liner but that's all
My wheel wells are worn down from an old 35" setup I had on. I went down to a level kit and recently had two brand new 305/55/20 terra grapplers put on up front and they found some of the wheel well to wear them down. It's the icon 2.5" mini pack, they rubbed for a day and don't anymore at full steer.
1 - 18 of 18 Posts
