1 - 3 of 3 Posts
Ive been debating weather to build my 7.3 up or not just not sure about doing so being she has so many miles and already spent alot of money fixing her up. So wanted some opions, build or leave alone?
If I build going to do:
160/100 or 238/100 Injectors(more then likly do 238)
D66 drop in
Regulated return(RR)
T-500 Hpop or maybe do a stealth
Valiar kevler single disc towing clutch (500/1100) and heim joint fix(replaces junk plastic bushing)
Egt/boost/fuel psi gauges autometer
Traction bars
4" Straight TB
Custom tunes
or leave alone:
Rebuild stock turbo(has slight plat and seals are letting some oil by)
Valiar clutch & heim joint fix
Gauges
Also going to see my buddy and see about having truck repainted same color tan but take black flares off and paint black along bottom(2 tone), really like that setup on superdutys.
Do a compression test.
Is this what you want it to look like?
1 - 3 of 3 Posts
