1 - 11 of 11 Posts
1999 crewcab duelly 4x4,
I'm getting ready to purchase 250cc 80% injectors and a 1250 cfm 68mm turbo with h2e mount setup. Does anybody have any input that i may be putting together a bad combo? and which of the two is my weaker link in terms of being able to handle one another? i just dont want to burn up the turbo while i want it to be pushed hard enough to make the quickest power i can with it! thanks any input appreciated
68mm? what brand Turbo?
I'm looking at going to a S470 with 238/100's possibly 200% nozzles
what do you have for hpop pump or pumps
Well Hung Member
im runnin 238/80%s and stealth dual pumps, t6 75/88 turbo's in the mail so ill let you know how it works
an S300 would be the turbo. seems like both of you are going to be running smaller injecters with a much larger turbo. Hey "stroked" what size turbo are you currently running? and what are you egt's getting up to. i just dont want to have to be light footed to keep from burning up turbo as soon as i install?
Well Hung Member
Currently running a 38r with a 1.15 housing, and sure with a heavy pedal it'll wrap that egt gauge right around but normal acceleration and playing around its not a big hassle to keep it under 1300*, and keep it the reccomended 40psi or below with a rare spike above, just remember what temperature alluminum melts at and worry about pistons and other internals melting and breaking down, not just the turbo, and yea my 238's won't be the ideal injector for that turbo, but the 300/200's that will happen a little later will fix that issue. But sure if you have no intention of further upgrades, a 38r and a 1.15 turbine would be an awesome match with 238's or 250's, but we all know how that is, if you're upgrading now get something with the mounting kit so you can easily and more affordably upgrade down the road
i was told that the 68mm s300 with 250cc 80% injectors would easily hit 50psi. is your warning of nothing above 40psi pertaining to concerns of headgaskets, headstuds, valve springs? or are there other things you were considering. thanks in advance!
Well Hung Member
mostly because a 38r with a stock housing isnt recomended for more that 40psi, other than that sure i would say get some valve springs and studs to be running injectors and a bigger turbo guaranteed, a lot better than poppin gaskets, and 40, 50 psi is definitely knocking down the door of doing that, and if youre doing those you might as well invest in some studs at least, easier to do it before the truck's broken down
Village Idiot
you'll prob want a better hpop..250 is getting large even for an adrenaline, but you should ask bob at dieselsite on that one.
i was looking at 250 injectors and a modded h2e or modded qssb
so i would think you would be in the range..go too big you will have lag until it lights then hang on. now as far as housing sizes ...i'll defer that to a vendor..like beans,di, swamps etc.
fueled by Colecovision
250 hybrids use EXACTLY the same amount of HPOil as a STOCK AD injector....
:doh: I hope that's not too much, for "even" an Adrenaline,
:lookaround:
I'd say exactly what an AD uses with larger nozzles (same nozzle as the Hybrid).
I see a psi drop with larger nozzles on the bench, so they need just a hair more oil.
1 - 11 of 11 Posts
