1 - 7 of 7 Posts
Wondering if I can run 20x12 wheels with 35x12.50 toyo mt with heavy duty front suspension and a leveling kit. Also needs pics from side with 12" wide wheels.
It should work with the leveling kit, you might rub a little on the plastic valance. I have a 2wd I'm running a 325/45/24 which comes out to a 35.5 I have a leveling kit a get a very slight rub on the plastic like I said mine is 2wd it sits lower from the factory
It depends on the offset but I'm running Nitto Trail Grapplers 35x12.5 20x9 zero offset Fuel Mavericks with a leveling kit and it barely rubs the radius arm at full turn.
I have 20x9 and 35's now just wandering on 20x12's with 4.75 back spacing
My buddy has 35x12.5 on 20x12 -44 off set with a 4" lift....he's got about an inch of clearance from fender to tire.
With just a 2.5" lift I doubt you will clear with out some pretty good amount of trimming. I had to trim to clear my 35's and 20x10's so with more negative offset means more trimming
The Diesel Cartel
Yeah this is going to require cutting or removing the bumper brackets, cutting the inner fenders, and possibly even more.
I just did a customers truck with Icon 4.5 and 22x12 American forces on 35" Toyos and it needed a good amount of cutting.
1 - 7 of 7 Posts
