1 - 10 of 10 Posts
Has anyone done one yet? I just finished and have a couple issues I need help with. p0243 wastegate sol A and p2185 ECT sensor 2 ckt high. The rest I think will be cured with a tune. Thanks in advance, Walt
sooty
The 17 engine has different turbo parameters and no wastegate solenoid, hence the codes. You need tunes for a 2015+ turbo and you should be all set.
Great! I have an EZ LYNK autoagent 2.0 unit that I tuned my 2015 F250 6.7 with hopefully 2015 and up tune will work on my 2011 ecm.
Most good tuners just modify the 11 flash. My 11 runs a stroker fuel pump and modded 17 turbo and runs just fine. Use a reputable tuner.
Thanks for the input. I need to get this truck running. Who would you recommend? I am waiting a response from GPD for my EZ LYNK. I have a referral to PPEI / Kory Willis but have not called them yet.
1 - 10 of 10 Posts
