I have a 2014 6.7L F450 ambulance that’s having recurring derate issues. The truck has been through the ringer of dealerships and mechanics to no avail.
Issues nearly always happen when the engine is cold (heated station so about 60*F). As soon as you leave the station and accelerate it gets about 50’ down the road and goes into derate mode. Sometimes it will throw codes and sometimes it wont. If it doesn’t go into derate in that beginning timeframe it will run for the rest of the call without issue. When it does derate the issue is resolved by shutting off and restarting the engine. It will not derate after the restart.
Codes found after derate are as follows:
P132B, P0234, P229E, P207F, P20EE, P1247
Most prominent to show are P132B, P0234 and P1247
I was able to get several derate episodes while on a scan tool. A few recurrent things I’m seeing right before derate is the exhaust pressure will jump from a PSI in the teens to 89 PSI, MAP jumps from teens to mid 50’s PSI and MAF from about 5 lb/m to 44 lb/m.
Would love to get this $250k ambulance back to being more useful than a boat anchor! Thanks in advance for your knowledge and help.
