1 - 4 of 4 Posts
I have a 2010 f250 with the 6.4. Mods are dpf delete, egr delete, turbo back exhaust, intake , spartan tune running 275 early lock. I have 37" tires on 22" rims. Gearing has been changed from 355s to 411s. Now here's the problem, gradually I have noticed the mpg getting worse and power seems to be dropping as well. Looking for and advise or ideas here cause I'm stumped
Moderator
Did you read the stickies.
What you're doing wrong: Big tires and higher (numerical) gear ratio.
I'm not at all suprised your MPG is going down.
Chachi
:whs:, and on that tune you probably drive with a lead foot... which Is another cause of ur mpg decrease
Moderator
Changing the nut behind the wheel (aka the driver) can make up for a multitude of sins.
I have a mild Swamp Donkey tune and I get about the same MPG as his MPG tune. I am a half-baked hypermiler (mostly I'm Sir Coastalot) and that might be why the performance tune and the MPG tune get the same MPG for me.
Having big tires and a numerically higher R/P ratio and visions of being Tony Stewart would lead to lower MPG.
1 - 4 of 4 Posts
