1 - 7 of 7 Posts
Does anyone have a checklist for maintenance once you hit 200K. My truck is about to roll over (tomorrow). I know there is the check list in the owners manual but is there anything else maybe i should do. Thanks
Premium Member
First open wallet, inspect for money. If there's plenty in there then spend it on every fluid/filter you can change.
"resident smarty pants"
hoses too
the same maintenance that is done on any other 200k truck, change all fluids all filters, fix leaks, and keep on driving theres nothing too serious about maintenance on these engines imo.
just do basic maintenance i.e. oil and filters. had a leak from tranny fluid filter but just replaced it along with e a new o-ring problem solved. probably time for a coolant flush Truck is an 04, so 03 engine i believe at least thats the date on my trans aswell. I plan to go through the book and do all fluids and other things i can afford. I need to do the blue spring update as another thing im sure its never been replaced. i didnt think about hoses thats a good idea.
Fixing Broken Stuff
1 - 7 of 7 Posts
