1 - 4 of 4 Posts
any one know if you can by adapters for the 08+ mirrors to fit the 01 Superduty wiring in the door or does any one know the exact pin out from the new mirrors to and the exact pin out for the factory wireing. i have buyt a set of mirrors that have heat, turn and marker. i have the marker, turn, and heat hooked up and only holding up with the mirror turn functions. i have the door plkug with only mirror function.. no heat turn or marker. pleaes help
Administrator
01 did not come with those functions so you will have to run the wires out through the dash and doors to the mirrors.
Search 08 mirror install in older sd trucks. Theres a bunch of writeups on how to wire everything. Pretty easy couple hours work,
Resident Curmudgeon
Doing it myself right now. Write ups dont cover everything.
My new mirrors have
Red
Yellow
green
blue
Grey
White
Black wires
Old
Red
Yellow
Blue. (Drivers side)
The ebay adapters do not correspond on color and do not fit the connector on the mirror.
I do not have time to go back and forth with the seller so i am cutting and splicing
Cant add photos from my phone
1 - 4 of 4 Posts
