1 - 3 of 3 Posts
Has anyone taken their power tow mirrors apart - other than glass or bulb replacement?
I want to run some wires inside the lower arm for a camera - so need to get the black covers off - and suspect might have to drill a hole in the mounting bracket to get the wire through - unless I can find a spot I can thread it through.
Any suggestions on where to find the full disassemble/reassemble instructions???
Thanks in advance
Bill
You're not going to find instructions for that, basically pop out the glass carefully and you will find I think 5 screws holding the mirror front and rear cover to each other, then separate and see if you can run wires down the track.
Administrator
there are some companies that have mirror replacement lenses and they post the directions on how to pop the mirror like Cody mentioned
1 - 3 of 3 Posts
