1 - 12 of 12 Posts
I am sure that its not new to anyone who knows the 6.0 to hear of a crank no start condition but I am hoping someone can help me to resolve this one. Last week the truck died on the highway. I managed to get off the road and it cranked back but only made it a mile or so when it died again. I have gone through what I know and have the ability to do at the moment. I am looking for any other insight as to what needs to be done next.
What I have done and tested for
Oil is fresh
New air filter
New fuel filters - upper filter fills quickly when key is turned on
Fuel pressure = 58#
Injector buzz test = all good
No apparent signs of chaffing in the wire loom
FICM power = 48V
Glow Plug Voltage = Truck Power (replaced the glow plug module because I had one - to no avail)
Battery = 13.4V
Cranking RPM = Good
Sync = Yes
ICP Voltage = 0.25V
IPC = only climbs to about 27 - disconnected the wire to see what default would drive it to - went to 1,600 so I believe the ICP is OK
IPR = 0 - Without the pain of pulling the IPR valve I cannot determine if it is failing
Any suggestions would be great
"resident smarty pants"
Disconnecting the ICP and cranking indicates that the PCM is not preventing a start because of a bad ICP sensor.
I don't really understand a 0 IPR % duty cycle though. That is a commanded value and it should be between 14 and 85%. The actual valve position is unknown because there is no "positioner" on it.
Do you get oil pressure on the dash gauge when cranking?
Check to see how long it takes to fill the oil filter housing when cranking (ONLY crank w/ the FICM relay removed or crank by jumpering the starter solenoid to the passenger battery (+) terminal).
If it fills in 10-12 seconds, then time to do an air test.
bismic1 - I just checked - the oil pressure is NOT coming up on the gauge when cranking. It is getting dark here so I will check the oil fill time on the housing in the morning
Pull the oil filter and disconnect the S terminal connector near the passenger battery and touch it to B+. The oil filter housing should fill up in about 10 seconds or so (without pressing the drain back valve). If you see ZERO rise, you have a LPOP problem. Remove the regulator (Allen bolt by balancer) and see if there is debris in it.
If it fills up properly, an air test is in order.
Thanks bismic1 and matthew11 for your responses - I had a rough couple of days at work so I just got around to checking the oil filter housing. I did the test and the reservoir fills up in about 8 seconds - looks like I am on to the air test. Couple of questions however. (1) what is the thread size/count on the ICP to hook shop air to and (2) I am still baffled as to why there is no reading on the scan gauge for IPR %. I though maybe I had entered the values wrong so I double checked and they are correct. If what I read is correct I should get something (15% to 85%) but I have no reading at all. Can tell if that fact is a contributor or the problem
IMO the best way to do an air test is with a test fitting that screws into the IPR valve port (ie remove the IPR and screw in the test fitting). Otherwise you have to have a way to close the IPR valve.
Before doing the air test, you probably should pull the oil pressure regulator (down by the harmonic balancer)
OK after checking everything I could and getting no negative results, I came back to the fact that I was getting "NO" reading whatsoever on the scan gauge for IPR so I bit the bullet and pulled the IPR. What a pain. After getting it off there is no screen at all. There are parts of the screen in the valve and a few pieces of the plastic that hold the screen. I intend to go ahead and replace the IPR but I have a couple of questions. (1) Since I was not able to find anything additional by fishing around in the IPR thread hole of the HPOP - am I OK to just replace the IPR? and (2) There are a bunch of IPR's on the market - I was told to go back with Motorcraft OEM, but even then there are conflicting part numbers for a 2007 6.0 - Can you shed some light on the correct part number? Thanks to all in advance !!
Motorcraft only. The screen is still in the pump you must remove it. Use a mirror to see inside the IPR bore
I don't quite understand how a bad IPR will cause no oil pressure reading on the dash gauge.
It happened to me mark, first time for me if you recall our recent PM conversation. It has been the only time too.
Thanks for the reminder Matt. I had totally forgotten. Just got back from the deer lease and was dog tired!
1 - 12 of 12 Posts
