1 - 4 of 4 Posts
· Registered
My dads 2006 F-350 has and eight inch lift on it with 37 inch mud tires on twenty inch wheels and he has done every thing that can be done a side from lowering the truck and it does what he calls the death wobble when he hits a bump and high speeds the front tires start to wobble and the steering wheel goes crazy he does not know what else to do any help would be great
Thanks
Gib
· Registered
First thing is bushings look at them first. Park it on LEVEL ground and make shure the drag link and trac bar are parralel to each other If not the suspention and steering are out of phase and it can cause the (death wobble). Also with tires that big make shure thay are in balance and not out of round.
· Registered
got them balanced and that wasnt the problem changed the pitman are and put a bigger tract bar on and nothing check every thing out and it was all good so then we decided to change the shocks and it fixed the problem so it was the shocks that caused it
later
gib
1 - 4 of 4 Posts
