I've read numerous posts on this forum and others via google. I have #5 and #8 as bad through the DTC reader of a Bully Dog Triple Pup reader. I purchased the truck four months ago (Sept) and the owner had already ordered a complete set of Motorcraft Glow Plugs and passed them to me when we settled the deal.
Between work and moving, I have not had time to attempt to install them. With the weather finally becoming cold, I am attempting this tomorrow morning. I do not have the "Stealership" tool to remove the harness plugs and have read even with the tool, sometimes the harness plugs still break. One post that I read, suggested taking a torch to warm the metal around the Glow Plug, to help soften/loosen up the o-ring. Reading that and the other posts, I am going to attempt this after the engine is warm vice cold iron.
Can anyone add suggestions or ideas? I've already seen the Ford .pdf of of explaining how to remove the glow plug and harness itself. I haven't posted much, but read, review, and study as much as I can to do my own work. Been worked over once too many by paying a mechanic or having the Dealership do work, only to redo it or take it back to be done correctly. Thanks much in advance... - Will
