Check for a brake fluid leak. If you don’t see any leaks (make sure the reservoir is still full) then check your hydro boost
Check for a brake fluid leak. If you don’t see any leaks (make sure the reservoir is still full) then check your hydro boostMy brakes went suddenly to the floor, they would pump up a little after accelerating but I can't figure out what's going on. Can someone help?
