1 - 1 of 1 Posts
2006 Ford F-250 crew cab short bed Lariat
Dark Shadow Gray with Gray Leather Interior
99,XXX miles
Sunroof, heated seats, tinted windows.
Bulletproofed at 90k miles as a preventative measure.
The heads were taken to the machine shop where they were fully inspected, resurfaced, guides replaced, valves checked (all were good).
The injectors were taken to be flow tested, o-rings checked, etc.
FICM voltage was perfect.
ARP head studs, sinister egr delete and coolant filter
OEM Ford head gaskets and updated oil cooler.
Updated IPR fitting, dummy plugs, stand pipes, turbo feed and drain lines
STC fitting, blue spring upgrade.
Extended Life Coolant (Ford Gold was fully flushed out using the suggested method on the forum when the truck was bulletproofed).
4" Flo-Pro exhaust
Edge Insight CTS (monitor only, not the tuning version)
SCT handheld with IDP economy tune (really only on there to remove EGR as the gas mileage isn't really much better)
Weatherguard "no show" toolbox
Line-X bedliner
Top of the line sound system with Kappa Inifinity Door Speakers, Kenwood Excelon XR900-5 amplifier, and Pioneer sub in a SPL2K box all professionally installed.
HID headlights
Nitto Terra Grappler ~33" tires with less than 10k miles.
$24,000 firm the way it sits.
I have one picture on my phone and more will come once this weather clears and I can shine her up. The underside of this truck is meticulous. Must see to appreciate.
Located near St. Louis, MO.
Texts are preferred. No trades please. 314-698-72-six-3.
1 - 1 of 1 Posts
