1 - 2 of 2 Posts
How do you replace the bulbs? Did they come out the back, or do you have to
remove the head light housing.
Thanks
Banned
pop the hood, you will see two bolts on the top of the housing....the is also two under the headlight
have to unscrew them and slide the headlight assembly out, you will need a 5.5mm
stupid idea ever if you ask me, but even what it says in the owners manual, i had to loosen the grill to get mine out. They use a 9008 bulb by the way.
1 - 2 of 2 Posts
