1 - 13 of 13 Posts
Hi guys,
Im in the process of converting to the 2005 front. I have the grill and headlights, just need the bumper.
My question is, does the 2005 header panel bolt right up in my 1999? I would rather do that instead of cutting my header panel.
Also, do I need the 2005 bumper brackets too?
Thanks
Administrator
Header panel will bolt right up.
I don't know about the bumper brackets. I would guess you would.
Thanks, header panels are not that expensive new, so thats good.
I like Diesel.
I'm in the same boat as you, as far as swapping front ends. I'm making my own headlights, and have already installed the grill and bumper. I directly swapped the 05 bumper on I didn't mess with changing the mounted or anything, but I imagine it would work either way.
Sent from my Gigaset QV830 using Tapatalk
I have my grill on, but need to still install the lights then find a bumper. At this point Ill just cut my header panel and put that money towards a bumper and paint.
Big dumb redneck
Header panels can be bought new for $50-75. ,y buddy just did the swap on his 99...found a panel somewhere online for $55. It's worth that to not fool with cutting and all that mess.
Thats what Ive been told my buddies that have done the convertion. Ive heard its quicker to do the panel, is that true?
Big dumb redneck
It has to be quicker than cutting/fitting. A header panel is less than 10 bolts I think...remove bolts, old off, new on, bolts back in. That way your newer style lights will just bolt right up to the new panel.
Basically just depends on your time available, if you like fooling with alterations vs just swapping parts, etc.
Administrator
You need the correct header panel or the bottom of the grill won't snap in. Because your doing the full conversion you need the header panel.
Yes, you need the bumper brackets as they are different from the 99-04 brackets. If I remember correctly, the outer "vertical" brackets are different as well. I had a set of the outer ones laying around, so I just used them, didn't compare them to the early style.
benny
Hi guys,
Thanks
benny
Thanks, this is exactly what I need to know. Helps me figure the total cost for the bumper too.
I currently have the 05 grill on, I know, I have zip ties on it. :laugh:
At least the top screws match up.:grin:
Big dumb redneck
LOL...zip ties and duck tape can make anything work.
1 - 13 of 13 Posts
