1 - 6 of 6 Posts
i have a 05 6.0 that keeps loosing water and cant find where also have a problem with it over heating when in a hard pull i pul a 12000 camper and when pulling up hill it will get hot if i run over about 50 any one have any ideas?
Is there any white residue around your degas bottle? Usually these trucks overheat when they get a little low on coolant. You could also have a blown EGR, causing the coolant to be lost out the exhaust...
yes white residue all over it but just thought it was from it getting to hot last night when i was pulling mount eagle.
The white residue is your coolant loss, the coolant is venting out the cap, welcome to the world of "puking" 6.0's! Could be a bad degas cap, blown/clogged EGR cooler, clogged oil cooler, or headgaskets.
Thanks I will start checking and see what I find sounds like more fun.
if you have a blown EGR, like as said above, it will go out of the exhaust. if it is, your exhaust will have a sweet smell to it and the smoke will be a little different in color as it burns the coolant thru and out the exhaust
1 - 6 of 6 Posts
