1 - 2 of 2 Posts
Howdy fellas,
Just noticed this condition. Truck starts, idles, and drives around fine at normal driving RPM. However, if I put it to the floor, it seems slightly down on power and kind of breaks up in the higher RPMs. It also has a slightly different exhaust note. EOT, ECT and Boost numbers look normal, thinking it may be a fuel issue? Not sure on fuel psi just yet, will be hooking up a gauge shortly.
Recently (within 2k miles) did an EGR delete, cleaned the turbo, and loaded a looney tune.
Also just started adding the supertech 2 stroke oil (really smoothed out the idle, significantly quiter)
Any preliminary ideas?
Thanks!
matt
sounds like your headed in the right direction
1 - 2 of 2 Posts
