1 - 6 of 6 Posts
You are going to have to start tracing wiring. Look under the truck around the bumper and see if you see any wires hanging down or that are near any metal.
Car manufactures started putting the taillights on the same circuit as the dash lights so that you will know that there is a problem
"resident smarty pants"
A TAN wire with WHITE stripe comes out of the CJB connector C270b. It is the ONLY wire "out" of fuse #17. It goes to the main light switch (dash) and to the Vehicle Security Module (behind the dash). Out of the main light switch is a BROWN wire to the rear tail lights.
1 - 6 of 6 Posts
