1 - 4 of 4 Posts
I had a buddy driving down the road yesterday to work. had been about an hour drive. The truck just quit and shut down on him. He still has battery power but the monitor will not read the vin or the truck. The odometer comes on but goes to dashes (--------). Has anyone ever had this problem?
His programmer is bricked
A stock flash from the dealer will wake it up but he's going to loose his tuner
could be a list of things. Need to get some more information on the truck.
I would try and get a scanner or computer on the truck See if there are any codes. No starts could be issues such as:
HPOP fail
STC fitting fail
HP oil leak in the system
IPR failing
ICP failing.
out of fuel
fuel pump failing
Ficm failing.
I would get some data on the truck before you just randomly go replacing things.
1 - 4 of 4 Posts
