1 - 2 of 2 Posts
like the title says i get in the truck turn the key wait for the glowplug light to come off turn the key and nothing where should i start to look? Everything works the lights do not dim when i turn the key eather. any ideas i need to use the truck any help i would appreciate it.
possible starter or relay/fuse.theres a connector on the pass fenderwell you can unplug and jumper a hot wire to to test that the starter engages.single wire connector,big fat(12-10ga or so)yellow wire right by the vacuum pump.
1 - 2 of 2 Posts
