1 - 3 of 3 Posts
Got the trany swapped and shifts great and runs great but I can't get the 4 wheel drive to work and I can't get cruse control to work any suggestions ???? Do I need a different grant harnis ?? Or do I need to just jump wires ? I could really use help I'm getting dissapointed
Does the 4x4 just not working in low range or is it all together dead? Also is it manual or electric? For the cruise, I would hook up a scanner and look at the inputs to see if the truck is looking for the old transmission to be in gear.
Also if you don't mind, I am in the middle of a swap too, do you know the thickness of the spacer between the engine and trans? Reason I ask is I can't find one anywhere and have seen four different thicknesses listed which makes it hard to make one myself.
The 4wd is electronic and it is all together dead also the plate is 1/8 inch thick and that's I'm port ant because I left it out and stripped my starter bolts and my fingers are always touching the throw bearing any other questions u have feel free to ask
1 - 3 of 3 Posts
