1 - 8 of 8 Posts
7.3 dead pedal no gauges replaced pedal and overdrive shift lever still no pedal.
Now what do I do? tried to search it but no luck.
Had that to happen to my '99 in extremely cold weather but worked after warming up. Replaced the PCM relay and it never came back???
Administrator
Usually there is a short in the shifter column for the overdrive button. There should be a blown fuse somewhere.
I know you replaced the pedal assembly, how did the harness look? Recheck the harness including all the pins. Was it a OEM or aftermarket pedal assembly? Any codes? A bi-directional scan tool is you best friend.
Exactly, it's a classic case. Here's a link showing how to fix it, also on your 2002 it will be fuse #45, I know you said no blown fuses but they can be easy to miss. I caught mine in the early stages before the fuse blew, (I was having OD button problems) and replaced the shifter and harness, the hole in the insulation was so tiny I almost didn't see it but I'll guarantee you it's there.:
https://docs.google.com/viewer?a=v&pid=sites&srcid=ZGVmYXVsdGRvbWFpbnx3b29kbnRoaW5nczh8Z3g6NzhiYWJjM2Q5YjdmODQ4NQ
1 - 8 of 8 Posts
