1 - 2 of 2 Posts
I have a 2000 F250 with 7.3. It has low power, heavy black smoke, and I believe codes P0221, P0478, P1247, and P1248. When it is running the worst it won't even shift right, especially at low MPH around town. Advice?
0478 - check the stupid ebpv - it’s probably stuck and probably leaking oil. No power when stuck
0221 - tps - if it goes bad no matter how much you stomp on the pedal - no go.
1247 - check the map sensor and hose
1248 - turbocharger no pressure. Boot popped off and or turbo took a ####. No air, lots fuel=black smoke
1 - 2 of 2 Posts
