1 - 6 of 6 Posts
2000 7.3 starts for 10 minutes then dies is this an idm issue or a high pressure oil pump please help thank you
don't play well w others
Mine was a tilt column ignition switch loose problem. Try that first
Shake the steering real good and start it see if it still exists.
If not look up from the floor at the bottom. Of the column, you will see the switch
Tighten both bolts on the end.
Hope that does it for you
PSN intsigator
Does your dash lose power also or does the check engine light come on when it dies?
Will it crack back over, if so will it start or nothing happens?
Does the wait to start light come on?
On your tilt column move down and or up and try in both positions.
  • Like
Reactions: Dustybumpers
How long has it been doing it?
Did it start gradually or suddenly?
1 - 6 of 6 Posts
