1 - 20 of 297 Posts
· Registered
Who's running it?
I have been and my truck starts way smoother and quieter, injector tap is very quiet, and I get about 2MPG out of it.
I recommended it to diezel dawg and he had similar results, right around 2mpg.
Who else is running it? :fordoval:
· Registered
Discussion Starter · #5 ·
Yep, it's good stuff. I'll be using it from now on. Gonna experiment with some other stuff soon, but this is working great now.
Advantages:
low freeze point, serves as anti gel
better than trans fluid, designed to burn where trans fluid is not
lubricates injectors for long life and troublefree operation
increases fuel mileage due to added lubricity and btu content
lubricates and protects entire fuel system.
better than most fuel additives because they are mainly Xylene or Mineral Spirits, yuck!
One thing alot of folks may not know is that with the introduction of ULSD, the minimum lubricity standard changed (lowered). The process of removing sulfur from the fuel strips away lubricants. In order to even meet this new, lower standard, refiner's created an additive pack that is put into your fuel by the delivery driver!
Here is an awesome link that explains it more in detail and better than I can.
Take the time to read, very worth it!
http://www.frontiernet.net/~mopar1973man/2002 Dodge/Tips & Tricks/2 cycle oil/2_cycle_oil.htm
I'm gonna try to get him over here....
· Registered
i was pondering that idea the other day but was worried about it gumming up the turbo on the way out
· Registered
Air you using 2 stroke oil that your supposed to mix with gas or 2 stroke motor oil from wal mart?
· Registered
I've been using Stanadyne Performance Formula since buying a case about 3 years ago. I based that buying decision on writings by TheDieselStop forum participants who seemed to be the most experienced and knowledgeable. My notes from that research indicate typical users estimated about 0.5 increased mpg. That's so far from this 2 mpg claimed observation that dual-tank mpg-meter-equipped truck owners shouldn't have a tough time distinguishing between them.
Here's my suggested test procedure. Fill front and rear tanks with the same pump's diesel but the different additives in their suggested additive/fuel ratios. Switch dash-mounted fuel-tank-selector switch between front and rear tanks. Set cruise control on a long, flat, windless Interstate highway. Do not change cruise control until test observations are complete. After a few A-B comparison tests constant cruise control on level highway, consistent read-out values should emerge for each comparison mix. Wait until 5 miles have been run after switching tanks to allow sufficient flow to remove the other mix before recording current instant mpg meter values.
Do I trust Ford overhead MPG meter accuracy? No. But that's not at issue here. What's at issue is consistency. Factory overhead meters can display differences sufficiently well to leave no doubt about significant mpg differences.
Aside from mpg gains, I KNOW from experience that Stanadyne Performance Formula can restore some marginally operating single-shot injectors to good performing condition.
John
· Registered
Discussion Starter · #11 ·
I dont have an overhead display.
diezel dawg and I both hand calculated filling to the top with liquid diesel every time.
Our findings only reiterate what a lot of other users have found with 2 stroke oil for a while.
Check out the MSDS on Stanadyne performance. Looks more like a harsh solvent than a lubricant. http://www.stanadyne.com/new/ppt/showfile.asp?id=4079
· Registered
so i need outboard premix (no ash/gumming type) and mix 1oz per gallon right?
· Registered
i will be hitting walmart tonight so i can try this out on my trip sunday
· Registered
i tried to go buy more at walmart here and they were sold out of the 1 gallon. So i went to Advance Auto and bought some Pennzoil outboard 2 stroke and will give it a try when the SuperTech runs out. I was amazed at the difference in mileage i got. I thought Gregrob was high when he told me about it, but i became a believer after the first tank with it. My first 170 miles on my tank were around town and then i drove the truck to bandimere and back for Truckfest and i still got 16-16.5 miles to the gallon and i hadnt seen that since before the ULSD came out. Previously i was only getting 14-15 on the highway with the ULSD.
· Registered
i will have to try it. when i get back from this sand box they call a country
· Hog Whisperer
WHat color is the two cycle oil? Some body brought up it looking like dyed fuel when mixed...?Tate
· Registered
Discussion Starter · #20 ·
Not at all. It's dark dark bluish green.
Trans fluid would look like dyed fuel, not 2 stroke. I've mixed it with a small amount of diesel and it just makes it darker. 1oz/gallon will hardly change the color.
1 - 20 of 297 Posts
