1 - 11 of 11 Posts
The Unseen Mod
Ok I'm thinking of attending a pull back home never done it before curious to know what should I do before hand like tire pressure, what gear ? build boost to what ? 4hi or 4 lo ? what to look out for ? etc
Banned
250
One word of caution. Pulling will consume you, so once you start, its the worst drug out there.
For your truck, 4lo, floor it and steer.
Cummins Power
BB is that pullers anonomous link up yet. Talk about being comsumed.
Max the rears to rated pressure and drop the front 10 or 15.
I do tires around 30, 4 Low OD off, turn up the chip and put the pedal to the rugs.
No need to build boost, my truck seems to build it quick enough.
i am glad you posted this 250. and by the way i think this is directed more toward the 6.ohhhh crowd
Building boost doesn't work so hot for me either. Seems I just blow all 4 loose and get a slower start than if I get the sled moving and let the boost come on about 10' out.
Just take the slack out of the drivetrain with a few RPMS, release brake and mat it, go straight :D
Regardless of what ya drive, tire pressure is variable on the track. Over time you'll figure out how your truck best reacts on tight/loose tracks and what to air to.
As for driving, some build boost, some don't. I try to get 10 psi ready, and roll it into the floor.
4 low, find the gear that works for you and kiss your savings goodbye. They're not lying. It's the greatest motorsport on the face of the earth :D
Not of this World
Since I was 2' tall I've loved pullin, finally did one in HS just before the Navy (finally had a truck to run). I think the Navy is all that stopped me from persuing it.
Now with more power I'm sooo tempted to start again, but every pull seems 2+ hours away and I'm worried about getting home if/when I break something. I've considered buying a cab/chassis w/ a rack as a hauler, atleast it would ensure I get home even if the pull truck is down. If I could find a local guy or two that wanted to team it, I'd probably go for it.
As stated, it is the greatest motorsport ever (offshore powerboat racing is a close second) and VERY addicting. I'd sign up for the pullers annonomous group awhile.:D
I am kind of new to pulling but I go 4 low in 2nd and I do pretty damn good. Ease into it 'til about the 50-75 foot mark and then floor it. That is my recommendation
all ur OBS r belong to me
Well you want to get your hitch at the maximum allowable height. I tend to leave the back tires pumped up hard and only adjust the pressure in the front.
I leave the line with about 10psi unless the track is really loose. 4Lo in drive and then after it shifts second I pull it down into second gear so it doesn't try to shift 3rd.
With your big tires, I would say 4Lo and floor it like BB said.
1 - 11 of 11 Posts
