Status
Not open for further replies.
1 - 2 of 2 Posts
1999 F350 CC SRW LB 4X4
Black exterior,gray interior.298,000 miles.
New Parts:
Phoenix 3 disc billet converter
John Wood valve body
Tranny pump
Bypass cooler line
6.0 liter oil cooler
Injector #3+#8
All injector o-rings and copper washers
Dino Fuels regulated return kit
Updated CPS
Dieselsite Adrenaline HPOP with new IPR
Dieselsite overboost valve and 203* thermostat
Up pipes and doughnuts
EBPV gutted and new turbo o-rings
glow plugs and relay
Power steering pump and steering gear
AFE 4" aluminized exhaust and stage 2 intake
Oil cooler gaskets and o-rings
DP Tuner with F5 switch
3 gauge pillar with Autometer gauges
DI stainless steel pre pump kit
VSS
Pads and calipar pins all the way around
Updated the front rotors to model year 2000
Front wheel bearings,axle seals,dust seals,ball joints and u joints
U joints in back drive shaft
Rough country shocks
Cooper 28575R16 SST tires
Extas not installed:
Trac bar bushings
2" front leveling leafs with bushing kit
Regular maintenance with OEM parts.
Interior good.Exterior fair at best.Some surface rust some through.
Asking $8,900
1 - 2 of 2 Posts
Status
