1 - 5 of 5 Posts
I took my rear bench seat out of my ext cab and cant find the 2 bolts that bolt it in place... Does anyone know the size and length and if I can just go to the hardware store to get them or have to have special ones from ford?
Thanks
Call the dealer and see if they will give you the specs in the bolts. Then I would go to the local hardware store and get grade 8 bolts.
You could also drive the truck to the hardware store and tell them you need to find out what size bolt you need, they should let you try them out. As long as you get the biggest one that will fit and it goes through the floor enough to get a self locking nut all the way on, you will be good.
Kenny
these are the bolts that hold the bench seat to the brackets.. not to the floor... it allows for the seat to flip over... one bolt on each side .... sorry for the confusion...
1 - 5 of 5 Posts
