41 - 60 of 99 Posts
Discussion Starter #41
PSN intsigator
Oh, for Christ's Sake . . . Why can't I get a complete gasket set????
It looks like all the ones that say no are RTV or orings. For RTV use Ford grey or permatex "the right stuff" in black
Discussion Starter #43
What . . . I have boatloads of the copper permatex that is supposed to be better than the black stuff.
Discussion Starter #44
I have these two pieces, which may be for the lug wrench, jack, and spare wich handles. I haven't the foggiest idea where they mount.
200617
The book says they mount on top of the radiator support.
200619
Does anyone have a pic?
Discussion Starter #45
PSN intsigator
Nothing is better than the right stuff made by permatex. In the black
PSN intsigator
PSN intsigator
Discussion Starter #49
Discussion Starter #51
ARGH!!!! I cannot find anything on the '99 Ford F350 cabin filter.
Does it even have one? If so, where is it?
PSN intsigator
I don't think it has one
Administrator
Don’t have one.
Discussion Starter #54
Sigh, it figures. Thanks, guys!
Got a lot done today - Transmission back in place and bolted in,front wheels on and truck back on the ground, received the motor and transmission mounts . . . .
Quite the fight to get the $%^& into place, too. Raising it for the mount won't be so bad.
200677
I took the transmission lines aside and used this stuff called Kooler Kleen to blow them out. What a skanky mess! Nasty, thick, black goo. I have some of the KK sitting in the transmission cooler in the radiator because I could not get it to go in one way and out the other. Blew some through with compressed air. Blech.
Discussion Starter #55
I thought that when you took your truck off the jack stands, it was supposed to look shorter . . . ? ? ? ?
200678
Also, I took the time to untape this . . . .
200679
And followed it to here, the other end, at the firewall, on the frame.
200680
Does this mean I have a block warmer somewhere?
PSN intsigator
You will, it is in your oil cooler/filter housing
PSN intsigator
Hmmm... Mine is mounted on the passenger side in one of the lower freeze plug holes.
Cj
I have never seen one there. You definitely don't have a stock heater
Discussion Starter #59
I don't think I can ever thank you guys enough! I am learning so much, here!
Administrator
If you ever need any pics. Let me know. I pretty much have the same truck.
41 - 60 of 99 Posts
