1 - 8 of 8 Posts
1999-2007 AMP power steps Ford Super Duty F-250/F-350/F-450 Crew Cab
these are used steps that I bought, I thought I wanted to install them on my truck but changed my mind. These are a used product and they do have a bit of wear on them as you can see in the pictures, the driver side has the most wear of course and its just on the edge, there are a few chips but should easily be able to be touched up. Also on each 2 of the 4 mounting brackets there is a bolt that was broken off that will need to be removed. And there is a small amount of red over spray on the end as you can see in the pictures. Overall, I think these are in good shape. I am looking to get $700.00 OBO for these shipped to the lower 48 states.
Here are the pictures
driver side wear
broken bolts
red over spray (probably come off with some goof off)
Thanks for looking.[
Texas Member
pm sent
Texas Member
can you get just the harness?
1 - 8 of 8 Posts
