1 - 2 of 2 Posts
My passenger side door won't open using the inside handle anymore. Parts house sold me a new cable to reolace the old stretchy one.. Problem 1) got the panel off and the 3 screws out of the latch. Also got the rods unhooked and the window track bolt out. I still cant get the latch mechanism out. It is loose in there but wont come out. I also cant see how the cable is attached to the bottom of the latch from the position it is in. Problem 2) WHere the handle is actually attached to the door(the hole) has been weakened over the 250,000 miles I have on it and is just about to break through. It is already broke through on one side and cracked on the other. I was gonna put a big washer and a new bolt and nut to replace it?
Demon Dually
Weld the piece of the inner door panel back together with a washer in there as well. If you have power locks you need to unhook the power lock actuator or you will never get it out.
1 - 2 of 2 Posts
