1 - 20 of 20 Posts
i have a 1997 and we put a different motor in it and we went to start it and we had the fuel bowl lid off and there wasnt any fuel coming in the bowl with the key on. Is there suppost to be any fuel coming into the bowl with the key in? Thanks
STILL LEARNING
And are you getting fuel into the filter housing?
STILL LEARNING
Either you are low on fuel and it is sucking air or there is air in the lines and you just need to keep cranking the engine over to purge it
okay is there anyway me might have hooked the fuel lines up backward because the fuel lines run down off the motor and they hook up to the frame rail lines because there two didfferent sizes on the motor and the go to the same size on the rail what would it do if they are backward
STILL LEARNING
They are different size on the frame rail, you cant hook them up backwards
STILL LEARNING
Depends. That may not even be your problem. You may have lost your HPOP prime
1 - 20 of 20 Posts
