Hey guys I installed a new south bend clutch, flywheel, slave cylinder and master cylinder, fork, throw out bearing, clutch pedal bushings, heim joint mod, everything in the clutch system is brand new. The slave cylinder is pre bled and working correctly. The truck will start and when I try to put it into first or any gear for that matter it will not go in, i do not understand whats restricting is from going into gear. Trying to fix it this weekend Ive been without the truck for two months because of it. Any help would be appreciated the fingers on the pressure plate are moving correctly and are level. There is really no explanation for why I can not get it into gear. Transmission is out of the truck right now I removed the pressure plate and theres no broken springs or bad fingers. Clutch disk looks fine as well. Thanks guys
