1 - 4 of 4 Posts
I recently purchased a 97 F350 7.3. It has high mileage, 280k and I don't have any records regarding the service the tranny has had. I Have heard it is unwise to change fluid and filter in a tranny if it hasn't had a fluid change in quite a while. The fluid does not appear to be burned but it's hard to tell. Should I just keep driving the truck keeping an eye on the fluid level? One thing I have noticed is the that the Trans shifts pretty hard. It isn't erratic though. Any input is much appreciated thanks!
Former Ford Trans Engr.
If it were mine I would change the fluid with the procedure that is a sticky at the top of this Forum.
If you want you could drop the valve body and clean that out also. When I put my shift kit in I noticed a lot of grey gunk in where the actuators are. At least that's what I think they are called. Wouldn't hurt to clean those.
1 - 4 of 4 Posts
