1 - 1 of 1 Posts
The truck was driven parked and when owner went to start just turned over.
Truck has had a recent crate motor installed as well as a lot of other work clutch brakes etc. Motor was cranked so much that it killed starter, which was replaced, so turns over and there is a hint of it firing at first couple of cranks then nothing, if you let it sit for a couple of minutes and try again it will try to fire then nothing again. This truck is an estate sale and is in another province so I am gathering all the info I can so when I go out there this Sat. I might have a fighting chance to get this thing running and drive it back to the coast. Don't have much time when I get there so have to do a quick diagnose then call a tow truck and try to find a dealer in the middle of nowhere. Have bought a new CPS to try, will check the HPOP oil level, also read to disconnect the fuel heater, as well as check two fuses, anything other ideas would be appreciated as these diesels are new to me. Thanks
1 - 1 of 1 Posts
