1 - 20 of 30 Posts
changed out fuelpump( calif. emissions) pulsation dampner, fuel lines from pump to head, now I have a leak on fitting on left side fitting fuel inlet to head. Are these fittings available thru Ford.... do they have the ck valve in the fitting??? is this part serviceable and having a long cranking to start motor.. must have low PSI in head any Ideas or fixes
On the fuel line side, that nut comes off and has a rubber washer inside.
If you are talking about the hard lines that go into the head from the lift pump, there are two small rubber washers Can be found here , sorry dont have ford number
Is the leak at the threads on the fitting into the head or where the fuel line joins the fitting? As 79jasper mentions, there is a sleeve at the fuel line-to-fitting joint. As far as I know there are no check valves in the head fittings. Cheers!
  • Like
Reactions: CA7.3
I installed new line set up it had new nut and rubber washer and the motor was cleaned before i started it and that is when I noticed leak after I installed all thislll
I found the fitting thru diesel orings and it has a ford number sounded like it had a ck valve inside...
So its not sleeves in the lines in back of head? or was it the return hose? if you replaced the hard lines and didn't replace the sleeves I would order those two because more then likely that could be it.
the new hard lines came with nuts and 1/4 inch sleeves in the or on the lines already they were ready to go....
there is no return hose in back of the HEad
it seems the leak is at the threads have to clean it and restart it to ck for leak
It’s probably the sleeves we where talking about
i will be looking at the sleeves and taking those apart and checking those out.....
Can you take a picture of exactly where leak is at?
sorry have removed parts already going out to get parts next...
No worries, if you get a chance when you get the stuff ect take a pic and post in discussion
Iirc, I tightened mine. I'm pretty sure it's a tapered thread.
Discussion Starter #18
1 - 20 of 30 Posts
