1 - 4 of 4 Posts
hi is there anyway i could take my zf5 speed and swap it with a transmission out of a newer truck like a 2000 powerstroke 6 speed. thanks
STILL LEARNING
Unless there is something SERIOUSLY wrong with your ZF5 and or you are getting a ZF6 for free. You are completely wasting your time.
you will need all new driveshaft and the SD t-case to go with the ZF6 and you will get nothing extra out of the ZF6 other than the expense
IMO the Z-5 is an awesome tranny. If you compare the respective ratios of each, basically the 6 gives you a lower granny gear so if pulling big loads might make sense for some. I think for the average guy you're better off putting the dough else where.
1 - 4 of 4 Posts
