1 - 8 of 8 Posts
Please help i am so lost!
I just installed a new kc 66/73 , irate diesel fuel pump and full force obs intercooler on my truck this week . everything went well and it starts and idles just fine but once i put in in drive and put under a load it does not want to build boost i just dumb fuel every time i step on the peddle i bellow black smoke . i am completely lost can someone help please .
Thank you
Premium Member
did you check all pipes from intake to air filter for blockage? that is what it sounds like.
Premium Member
the only other thing would be a non operational turbo. remove the air intake from the turbo and see if it is spinning with the engine running.
It will only make substantial boost under a good load. Is your MAP functioning OK? Hose to it hooked up? Cheers!
Are you running upgraded injectors? That's a lot of turbo for the small stock sticks. KC recommends 180/30s at a minimum.
1 - 8 of 8 Posts
