1 - 3 of 3 Posts
I have a 1994 F350 turbo diesel that just shut down suddenly while driving down the road. I cranks fine but appears to not be getting fuel. I disconnected the fuel pump and it is pumping sufficient fuel. I took the fuel shut off solenoid loose and it is opening and closing normally. I replaced the O rings around the fuel injectors because some of them were leaking. The truck stil will not start. The truck acts like it wants to start but it is not getting the fuel it needs to start. I have tried both fuel tanks. I put new glow plugs in it about 3 months ago. Any suggestions?
1997 F350, CCLB, 5 speed, Diamond Eye 4” w/ 3” dp, 4.10s, 6637, Edge CS (not for long), 12K lb winch
Have you changed out your cam position sensor (CPS)? That can cause the pickup to die just driving down the road. On the bright side, it’s an easy fix to check!
If you have a fuel shut off solenoid then you are in the wrong forum, you need to be in the Turbo IDI forum. This one is for the Powerstroke engine that came out in 94.5.
1 - 3 of 3 Posts
