1 - 9 of 9 Posts
Started life as a 1992 F250 with a high horsepower panty dropping 351 windsor, and thats right...a 5 speed manual to put that 200hp and 315ft lbs of input shaft snapping torque to the ground.
Got smashed into by a buddies 96 powerstroke
Then the tear down came
And some more tearage downage
Look at all that rust from under the 5th wheel plate
Stripped down to bare frame, painted with por 15, kp dana 60 installed and 6 inch tuff country lift kit installed
Pulled the engine out of the derdge
Engine in the Ford using Ford Cummins mounts
Bell housing adapter for a getrag to nv 4500 conversion
Merica' beer pong table and transmission installed
New cab on and making progress
More progress, found a rust free bed and test fitting tow mirrors
Body work almost finished, getting ready to be sent to Line-X of Mason City, Iowa
Fresh out of the Line-X shop
Put back together
No pics, but installed a 3.5 PMF rsk and lowered the rear back down quite a bit, now it doesn't ride like a dump truck!!!
And the most recent pic, playing in the snow in the middle of our field
Discussion Starter #2
And the dude that did all this work between my sophomore and senior years of high school
That looks like a clean swap bud. Can't wait to see the next one.
Thanks man, the next one won't be a restoration but I will take tons of pics of the swap and try to make it look like a factory install.
great looking truck, 3 questions though. first, who makes those rims? second, have any pics of the motor in? third, if you don't mind telling, how much was it to line-x the whole truck?
Eagle alloy makes them, I do have a couple pics of it in, and it was 4500, to do the whole truck red plus have the inside of the bed done in black. If I did it over the only things I would change would be a pmf 2.25 inch lift, zf6, and 33 inch mud tires instead of 35's. And probably start with a rust free truck.
The rims are made in USA and they are 186 series. 17x9's
Discussion Starter #9
figured I'd give an update on this thread, truck runs great has been a lot of fun over this past year and it's getting about 16 to 17 miles to the gallon average. As of right now its got 5650 miles on it.
1 - 9 of 9 Posts
