1 - 7 of 7 Posts
Have to put up for sale my f350, its a 86 cab and chassis with a iron and wood flat bed. 6.9 idi t19 2wd truck it runs and drives. has 124k WELL documented and accounted for miles on it. smokes on start up. i believe there is a small air leak because it takes 2 cranks after it sits for a week. fired off with no block heater this morning at 27 degrees.
I have been slowly working on it for over a year. purchased it from a buddy with a plan to fix it up and use as a work truck. now my powerstroke needs a clutch and jobs not looking to good for a few months so have to sell some things
bed is rusting out in some spots, i was going to reinforce it with wood or weld a few pieces of angle iron, it hauled a load of firewood down the street a few months ago so not too concerned.
heres a list of what i have done in the past year:
New valley pan
new return lines, tees and orings,
valve cover gaskets
all new rubber brake lines+ pads + calipers+ rear drum hardware
rear axle shaft seals
3.5 stock exhaust off of a 1995 powerstroke
all coolant hoses replaced, system flushed, scas brought up to spec
added banks intake lid with an oversized paper element(lid came with k&n)
Converted fuel filter over to 7.3 filter with screw on bottom
8 new berus with push button switch
Interior
painted all interior panels blue, came out awsome
white guages
clutch pedal is lower than in my powerstroke, im not sureif this is normal, fluid is ok and there is no cracking, operates fine :dunno
I purchased a hypermax kit from the junkyard over the summer, it wa out of an 87 350 2wd with a c6. i had to make a small dent in one of the pipes to make it work but its in. hooked everything up and the turbo appears to have a slight oil seal leak on the turbine side, no rubbing of the wheels and housing or leaks on compressor side. hypermax quoted 125 for rebuild kit.
It will moove in its current state but is leaking oil out of the exhaust housing and will need to be adressed before taken out on the road. came with the hypermax boost gauge/pyro but unfortunately the leads for the pyro were cut and i could not find a bung in any of the pipes.
here is the parts it comes with:
8 injectors from junkyard with unknown mileage out of turboed 87 6.9
injector pump with unknown mileage out of the 87 the turbo came out of
injector pump out of a 93 n/a 7.3 with 23k miles on rebuild
injector pump out of a 88 7.3 with unknown miles
2 or 3 complete sets of injector lines
1 used working 6.9 vacuum pump
1 used 6.9 alternator
1 new 7.3 alternator with external regulator
few used cdr valves
stock intake lid
trip odometer
tachometer of of a 1993, wired in
larger oem towing mirrors
polurethane axle pivot bushings
poly radius arm bushings
chrome headlight bezels
black headlight bezels
black grill guard
Lund Visor(needs to be painted to match)
other random odds and ends
I feel that with all the parts and the truck $2000 is a fair price. i do not want to separate any parts at this time, i will still be loosing money but unfortunately my dual mass flywheel in my powerstroke is about to shoot out so im gonna have to give something up. if any questions, i can be reached at (2 oh 3) five too too -too zero one three , names Ryan, live in Connecticut. If interested it would probably have to be towed as it is not currently registered or insured at the moment
FOR $2500 you can take the truck my project boat that i have been working on during the off season, 1986 larson 17 bowrider with 3.0l GM 4 banger WITH trailer new ignition system, doing all new gaskets this week, cant get the outdrive to go go down, only up. starter is acting up sometimes too. I will let it go to an oilburner or someone on PSN if they wish.
MAY BE INTERESTED IN TRADES FOR POWER EQUIPMENT, feel free to run anything by me
PM ME YOUR EMAIL FOR PICTURES
Discussion Starter #2
<-- Fat Bottom Girl
Price?
2000 obo with all the parts
-400 no turbo
less if you dont want some of the parts,
Still for sale, title in hand, Put a carrier electric fuel pump on, now it starts like a champ.
MAKE ME AN OFFER!
1 - 7 of 7 Posts
