1 - 14 of 14 Posts
My injectors are going out so I decided it was time to replace, and since I’m going to replace them, I would like to upgrade them. I’m currently looking at 180/30cc full force injectors with gearhead tunes to go with them. Just wanted to see if I should upgrade/replace anything else to support them. Truck already has CAI, exhaust, intake plenums, and up pipes. Was also planning on throwing in a wicked wheel 2 (diesel site giveaway I won a few months back) and an edge monitor for gauges (got rid of my glowshift gauges along with my other pickup) thanks!
Hpop lines, fuel lines, plenum inserts. Pedestal delete. If staying with the oem turbo, rebuild it and get a ww2. @[email protected] corey will hook you up or shop where it’s more convenient for you.
The ww2 will definitely be going in, it’s been sitting in the garage for months now. Don’t think I’ve heard of plenum inserts, what are they? And why the pedestal delete?
Pedestal delete cleans up the valley for potential leaks
Plenum inserts allows you to torque down the boots wo crushing them
I knew I forgot something. I am running riff raff boots. But I will look into the inserts. Thanks
If you have aftermarket intake plenums, I'm guessing RiffRaff since you also have their boots, then you do not need plenum inserts. The inserts are only because the stocks ones are made of flimsy metal that cannot hold up to the clamping pressure. Aftermarket ones should stand up to as much clamping force as required.
Ok, yes they’re the riffraff ones. Thanks! What brand of pedestal delete should I go with?
#1, 3, 4, 5, 6, 7 etc. some links I’ve saved below for reference and an idea of what I’ve stated above.
I highly recommend these as a MUST from a reliability standpoint. Items I’ve purchased.(Updated 2/19/18)
1. Pedestal delete, and Garrett hotside http://alturl.com/x4ihd $250. Garett hotside fits cleanly vs generics
2. KBDP bellowed up pipes http://alturl.com/9qpeh $200.
3. Plenum inserts http://alturl.com/eppso $51 shipped
4. Fuel bowl reseal Ebay user: racecolo best instructions ever! Dummy proof trust me! https://tinyurl.com/ydxtyro9 $20 shipped
5. Fuel lines https://tinyurl.com/y8n4wnhs.us $280 shipped
6. HPOP reseal Ebay user: racecolo https://tinyurl.com/ycrzvjee $29 shipped
7. HPOP lines Ebayer: crudediesel he’s local to me https://tinyurl.com/ycmlqfsb $155 shipped
8. Turbo rebuild: Ebay http://alturl.com/xrxtg $65 shipped. Has 360deg thrust bearing
9. Turbo outlet o-ring: Ebay F81Z-9E436-AA o-ring $8shipped
10. Upper radiator hose amazon #62491 $17 shipped. Route behind serpentine belt
11. Derale 14208 4r100 pan (adds 7qts extra) $130 http://alturl.com/kxbdt
12. Total: $1206
Got another question regarding the pedestal delete. Read some more on it and saw some guys just plugging (“deleting”) the stock pedestal, would this be comparable to a new deleted pedestal or should I just replace it? Thanks
You can plug and delete the old one it makes no difference. If you have the time plug and delete the stock one it save you some money.
Stop reading into it and buy the deleted pedestal. Make sure the hotside is a Garett so it lines up perfectly.
1 - 14 of 14 Posts
