1 - 5 of 5 Posts
Yes I have a chance to get a 17* pump but the problem is they will need mine as a core no big deal but the fact that this is my only truck and I need it every day can I install the 17* pump one night and do the drain back mod another so the truck wont be down???
Fill out your sig so we know what year truck you have....and what mods you've done...
<---F350 DRIFTER
drain back is on 94 and some 95s if you are not doning injectors not much need for a pump. if you are I would go with the Adrenaline HPOP
Hold on-- there's too many options now to have to do a drainback mod. The drainback mod is very risky and can ruin your timing cover or cause a leaker (i've seen 2 where this has happened) if incorrectly executed. Terminator can put modded 17* guts into an early pump case and/or you can get the adrenaline in an early case.
1 - 5 of 5 Posts
