1 - 5 of 5 Posts
Can anyone tell me ...
If I get the 17* HPOP Lines what are the differances?
Other than the way they mount to the Pump??
Will they change the location in the heads??
Meaning moving to a differant Port???
Any Pics??
Thanks
John
OverFuelingForYourPlesure
the newer engines used differant lines but you can reuse your old ones they will still fit in the 17 degree pump. or you can use the newer stile lines I think you would just have to move a plug in one of the heads to do that, but nothing special required to do it either way.
I prefer the OBS lines(-6JIC). My 95 still has the original lines.
FWIW, we just LIVE tuned the truck last night and it was holding 3700psi under 3/4 throttle. As long as the lines are not kinked or twisted up, they should live many years.
OEM Moderator
I agree with Joey. I would just swap the pump fittings from the old to the new pump.
Tom
Thanks for all the replys.
I guess my lines look OK
I was seeing some people had a cross over line from Head to head.
If I were to do I would have to move the Drivers side HPOP Line forward 1 hole.
So I am guessing that the ones I seen were 99+ ??
Thanks
John
1 - 5 of 5 Posts
