I purchased a '16 F350 / 6.7 with 122k miles about a month ago from a dealer mid-way across the country. About a week after buying it and driving it 2000 miles, I was driving (empty) down a long hill when I felt a violent shudder / knock and quickly pulled over. The local dealer wasn't able to diagnose other than a cylinder 3 misfire and 7% loss of compression, so I had it towed it to a specialty diesel shop.
They pulled apart the oil filter and found metal shavings. They are recommending a full engine replacement ($25k), or $5k in parts & labor if I supply my own long block + turbo. They also stated that there was no way the extent of damage witnessed occurred in the week that I had the vehicle.
I'm working with the selling dealer, who acknowledged that the wholesaler they acquired it from "did some work on it". They indicated that they would work on "making things right", but I'm obviously not 100% confident in this until it actually happens as I always plan for the worst.
I'm looking for some guidance on the following:
1) What's a reasonable cost for a long block replacement, both cost of the long block & labor+parts?
2) The diesel shop mentioned that Ford made some changes to the turbo, so I'd have to replace it too. Does this seem right?
3) Am I better off just finding a used engine, swapping it in, and then selling the vehicle?
4) If I just sell the vehicle as-is, how much of a hit will I take? I'm trying to figure out if it may make more sense to just sell it and let someone interested in dealing with the problem take care of it, though I suspect that's not a great idea.
Thanks for any guidance.
