1 - 11 of 11 Posts
I'm looking for a 12 volt timer to run my 04 heated/signal mirriors that I have installed on my 99.5. If anyone knows of any info on where to get one that would be great.
Administrator
so your going to hold the switch down as long as you want to activate the heat ?
I would use that and the DEI unit you would push the button you found and it would activate the timer for the duration you set
use the dei and a oem rear window defroster switch
no, it's just like a factory switch. you push the switch and it shuts off after 4 and half mins.
The Oracle
where are you getting that? the ad just says its a momentary SPST, which means its only activated when its pushed in
I love you bigrpowr!
What he said is correct. You would have to hold this switch the entire time you wanted the power. This switch is meant to only activate while you are holding it down.
Discussion Starter #9
I've got the switch installed now. It's the normal rocker switch that has a 4 and half min timer.
1 - 11 of 11 Posts
