1 - 15 of 15 Posts
Motorsports Performance
Well got my sisters boyfriends truck at the house waiting on wheels and tires want to run a 12 wide rim and he wants the bfg km2 which only comes in a 37x12.5x20 but if it steps up to a 38 it goes to a 14.5 wide. will that look ok with 12 inch rim n 12.5 tire. Truck is a 2003 with 6 inch super lift. Does any body have any pics and feel free to comment
IMO the 38ms would look better. But they're going to rub quite a bit. Especially the 14.5 wide. That is unless he trims his fenders and throws on the biggest set of buschwackers.
Right but I think we plan on running the Pocket style flares guess maybe he will have to step down to a 9 inch wide rim
I think the 12" wheel will still look good. It'll be a little streched.
<--BAGHDAD
imo 6" lift and under, i would go 37" more like 35"s tire or less. 8" + lift 38"+ tires and so on. i think a 6" with 35's look better. i had 35x14.50x15's on my 79 and it only had a 4" lift and it looked good. it sat just as tall as my buddy's z-71 with a 6" lift and 35's.
<--BAGHDAD
the km2 also have them in in 325/60R20 which will work with the 12" rims and are 35 1/2" tall tires.
We I have a 37 under my truck n think it looks sick IMO I think 35s are to small for 6 inch
<--BAGHDAD
i think it depends on the truck though too. i think 37" to me is the cut off on height to 6" lift. 38"+ needs 8"+ lift i think. has he thought about a different brand or style tire or possibly different rim to get the height and width you want
Discussion Starter #9
Well I've told him bout other tires but he wanted km2s but I'm gonna try again and I wanted to do a moto metal 962 because there new and haven't seen anyone with them and wanted a somewhat deep offset
I'm runnin 20x12 rims with 35x12.50 hankook A/T's on a 6 inch fabtech lift. I couldn't be happier the fit is perfect! with 37's I rubbed pretty bad with the wide rim.
Definitely go with the 37, maybe even a 35. The smaller tires look good with more lift if you have wide rims.
The tire won't really look stretched, but the sidewalls won't be pulled in. Here's a bigger pic of my avatar which is 18x12 on 33x12.50
run the 37's he'll be much happier and it won't rub Chris, the look will be killer too.
Chad
Right I'm running the 24x12 with the 37x13.5 n no rubbing but the only m/t in a 37x13.5 is a toyo what do you think chad should I get the bfg km2s like he wants or try n talk him out of it n run a toyo?
<--BAGHDAD
i think toyo's look better imo. also, i dont know about the km2's, but i know of 5 guys that ran bfg at's and they blew out the back tires and took their rear bed side with it. when i get tires, i look at the load range options too. i go with a range E, and if it is a D range then i look into the max load range and road wear rating.
Chris, definitely run the toyo, the bfg's are good but the toyos are.definitely the best IMO. Im running them now again for my 4th set.
Chad
1 - 15 of 15 Posts
