for those of ya'll that have DP tuners is there a lot of difference between the 80eco and the 100 race tune?
I got the next revision to the 80E yesterday. The 3-4 is now around 48mph minimum. That annoying OD lugging is gone, but you have to sacrifice some of the OD coasting/TC lockup so it can spool up when you hit the pedal. It locks up a second after you hit the go pedal. In OD, it drops to idle around 40-41mph rather than the 37mph. If you cancel out OD, it holds down to 27mph in D. I've only put 12miles on this tune, but I think he corrected the bulk of my list. I need to drive it a little more to try different scenarios.I find that shifting into overdrive sooner with the 80E lugs the engine a bit too much. The 80E is otherwise a very good program.
